Luke_Miller
Browsing on the internet I came across this site http://www.speedbleeder.com/. Has anyone used this before? Does it look like a good idea? BTW I am in no way related to this site. I just want some expert advice. TIA.
I don't want to run back and forth. Are you guys
i have them too! they are great!
if you have late 98 SVT the front should be SB8125L.. (8x1.25mm) they where way smaller that the ones that were send.. SB1010.. I'm told the SB1010 are for the older calipers. The rear are all the same for all years.. SB1010S
hope this helps
Then why are the 95-97 listed as SB1010 for the rear?
if you have late 98 SVT the front should be SB8125L.. (8x1.25mm) they where way smaller that the ones that were sent.. SB1010.. I'm told the SB1010 are for the older calipers. The rear are all the same for all years.. SB1010S
hope this helps
Luke, any luck with a response from them?
