jimjam63
New CEG'er
Hi,
I just acquired a 1998 Contour SE with 72,000 miles, V6 and a stickshift. It's never been in an accident or in a flood. I should note that it has been sitting for almost a year. Here's a list of troubleshooting performed---
1. I tested the ignition by running engine with starting fluid for a
few seconds.
2. Check engine lamp seems to be slightly illuminated but when we
checked with a code reader there was no fault.
3. While cranking the engine, the code reader had a message "misfire
detected".
4. Fuel pressure is ok while fuel pump relay is "jumped" on.
4a Fuel pump turns on for a second when key is turned to on position.
4b Fuel pump relay does not stay on while cranking the engine.
5. Engine will not run even with fuel pump "jumped" on while cranking.
6. Crank and cam sensors both pulled and cleaned, looked fine.
It really sounds like it wants to start and run on it's own, kind of like a timing issue or maybe a fuel injection problem. I can't afford to waste anymore time guessing, can one of you please :help: me out.
I did spend a couple hours going through the CEG forums the last week or so and there's some great information there, just not enough to start this car!
few seconds.
detected".
