Okay, so all weekend at SZ my car was driving around just fine no major driveability or tuning issues.
After consulting with Warmonger and others I knew I would need to replace my PCV valve (the old one was not sealing at all), and get my valve cover vents which were venting to atmosphere plumbed back into the intake after the MAF and before the turbo. All seems simple right.
So Sunday after SZ I stop in Kzoo pick up a new pcv and all necessary parts to route the VCV appropriately. Job done in a quick 60mins. Now the car is a stall machine. It runs pig rich on the highway, will stall at lights if I do not feather the throttle, bucks like a wild horse at very light throttle cruising (1st and 2nd gear is terrible) I can get rid of the severe bucking if I get into the gas more.
I have now, as in this morning, redone all hose connections to eliminate vac leaks if they exisited there. Cleaned the MAF. I have reset the PCM, all to no avail. I am using the same tune(s) that were fine since the car got running. I am almost out of ideas.
Maybe a vac leak under the intake manifold, but I do not know how it would have manifested itself while sitting in a driveway undisturbed.
I am about to leave for work and will try venting the VCVs to atmosphere again just for the heck of it. The only thing I cannot completely rewind is the PCV valve as the old one is in a garbage can in Kzoo.
Any ideas?
Any ideas?
