The needle on the coolant temp. gauge will suddenly swing all the way to "hot" when I start the car. It will stay there for a couple of minutes, then will slowly fall back down into the "normal" temp. range. It will run in the normal range for awhile, but will eventually creep up into the "hot" zone again.
It has been doing this since Sunday 5/20/07.
There is coolant in the system. There are no signs of coolant leaking that I can tell. I had the thermostat replaced approximately 2 1/2 years ago.
