Pen_Two
Is not easliy amused.
Ok, so the original fabric bombed on me and found every dimple in the stock foam. So I decided to use something less revealing and heavier. Well, I got home and figured I'd just apply the adhesive to the already set initial black layer. Then I tried to apply the new choice of fabric. No dice. It pissed me off, so I ripped the first failure off to try and apply the new stuff to the foam. Well, the adhesive I'm using apparently did it's job so well...it ripped off foam spots. ****. Now I had to do something about that. Thankfully I remembered the one fabric place I went to was going out of business and has about 3.5 yards of "Headliner Foam" left. So, I had to buy the entire 3.5 yards because that particular section requires a minimum of 5 yards or the entire bolt of fabric. It was $9.99 a yard, but they were liquidating everything (including lighting fixtures) so I got it at 85% off. So I got off as much of the stock foam as best as I could, and applied the new stuff. Unfortunately I ran out of glue so I only got the foam liner on.
Now that you've read that novel, here's the new foam.
And here's the new material I picked (I wanted it to be "different").
