high speed cooling fan does not work
johnoh
New CEG'er
I recently got the cel code for the high speed fan not working. I can't remember if it was code 563 or 756 and the car is not with me right now, but nevertheless the radiator fan is not kicking into high speed with the a/c on or right after you turn the key when you check for trouble codes after hooking up the obd-1 with a wire. Can someone post the troubleshooting steps for this problem? The fan wires themselves look to be okay. Thanks
By the way the fan used to be intermittent so I implemented the fix posted here where you splice the wires just off the fan control switch, which then caused the fan to always be on high speed. That was 3 months ago and since then the fan has always been on high until this week when high speed crapped out altogether. I just reversed the fix and high speed still does not come on.
Start with Fan topic If the motor is bad (stiff to turn), it might run too slow. The relative speed should change when testing the fan if the wiring and resistor are good.
