Wasn't really thinking of using Freon, (note the ? mark after the term), just didn't know what the current coolant was called. Freon seems almost a generic term, like give me a coke but I really want an Orange soda. Did do a search & didn't find much. Maybe I'm just using the wrong term.
Anyway, I suspect there is a leak, but it's apparently very small as I need to recharge it every other year.
So back to the original question. How does one recharge the system, as it doesn't seem to take the can if using the simple recharge system offered by Walmart/AutoZone. I have noticed Autozone offers a more expensive recharge system. Or am I just wasting my money buying those kits and should have a garage do what they know how to do.
well I am going to apologize some, I came off harsh, didn't have a good night at all ....
first off it may not have taken any refrigerant because the system maybe full ... and being to full is as bad as not being full enough ...
first step, verify is the A/C clutch is working correctly .... does it cycle? should cycle under about 90 degrees or so or be on constant over 90 degrees or so? if its not turning on you need to test the clutch and check the air gap.
next what are the pressures in the system? if you really want to do the work yourself you need a gauge set that allows you to read high and low side pressures. For the system to work correctly the high and low side pressures have to be in a certain range based on the ambient temperature, there also has to be the correct pressure differential. This is why you shouldn't use the wal-mart/autozone refill kits and they only read low side pressure and that is half of the picture. you can get a gauge kit at autozone for about $50 or $80 for the "professional" kit ...
next if the pressures are low and the system is fast cycling I would get a can of R-134a with the UV die ... again its at autozone and get the light and glasses and you will hopefully be able to find your leak. My bet, its the accumulator and that isn't to hard to replace. Remember that any connection has o-rings that need to be replaced with A/C o-rings. You will need A/C oil and I got some at wal-mart, but I forget how much the system should have it it ...
now to fill the system correctly it needs to be brought to a vacuum. Now your not suppose to fill the system with the small cans but it will work. You can get a venturi vacuum pump for the A/C system from like Eastwood, iirc that runs on 90 psi shop air.
once the system is sealed up correctly and brought to a vacuum then you can fill the system.
Its isn't good to fill the system otherwise because you could be introducing air to the system which will lessen how well the system works
