KingpinSVT
So, I was about to give the old muratic oval dip a go to remove all the chrome. I remembered an old thread on the ubb forums (dont know who started it, Pete maybe?) about peeling off the chrome by hand. IIRC, the poster was trying to sand it off with a dremel, and gouged up the plastic in doing so, but noticed the chrome would peel off when he pulled on it.
I figured I would give this a go, minus the dremel. I took a straight edge razor and made a small chip in the chrome with the corner in order to get under it. I was then, very carefully, able to "shave" off the chrome. Most of the time in very small chips, but I was able to get large peels off. The razor blade slides easily between the chrome and plastic at the right angle. And once you get it started, you can sometimes keep sliding the razor and remove a large portion. Also, sometimes you can grab the edge and just peel the chrome off by hand.
The rounded edges and the sharp inside curves at each end posed some trouble, but I was able to either gently use the razor to remove the chrome as best I could or sand off the chrome there by using the dremel with VERY LIGHT pressure, and going slow as to not leave scrapes in the plastic. The dremel still left rough spots (so only use it when you must), but I was able to go back and sand them out. I used the dremel to clean only the tightest spots on the inside sharp curves as mentioned earlier, maybe 1/2" total on each side.
Im sure I left a few small cuts in the plastic, but tomorrow I will be going over the oval and filling all these small imperfections in with bondo. My oval is now completely chromeless, and it only took me about 2 hours. A large improvement over the sometimes 2 week wait with acid, or crappy results with sanding.
