BurritaSVT
I am sorry to say first off the engine more than likely won't make it to SZ 2007 due to engine problems beyond my control. F
First off we all know I spun a rod due to thin oil and high heat on the oil side. When I tore the motor down I saw every journal in the motor was blueish meaning the oil was so thin and hot I had no protection on the motor journals.
I also had another crank redone I had a 2.5 liter crank (that will allow my motor to spin over a 3 liter crank) It will also give me faster accelration since the counter weights are closer to the center axis of rotation. Also will be less oil resistance going through the oil pool for less resistance. The crank had to have mallory plugs drill and welded in the crank to add the weight needed to balance the smaller crank to the 3 liter. The darn plugs were $75 a peice wow. but I am excited to rev this baby over 7500rpms.
Well the real reason I posted this info is because I noticed that various pistons were rubbing the block on the skirts. My engine builders builds more high performance motors than most shops do. The guy does viper motors that are in the 9 sec along with other top fuel cars. He is bery knowledgable too. And when I was boring the block I told him that diamond wanted to have th eblock between 0.0045 and .0005 over piston size for ring clearance he was shocked and said that was to tight. I listening to Diamond stayed with there specs but when I brought the pistons and block to him to show him the scars the skirts made on the cylinder walls he said I told you it was to tight.
So basically he saying that in a turbocharged car you want the pistons to have more clearnace than a NA motor due to the expansion of the pistons. I remember my 2.5 liter motor was the same and I blamed it on detonation but I really think I have a repeat here.
I like to know if anyone here has taken off some diamond pistons once ran with miles and noticed any similar rubbing of the skirts. I know it is somewhat normal to have small contact but not enough to scar the cylinders.
Well I have to rehone the block .001 over and buy new rings so I will build the motor next week and If I am not busy at work I may get lucky and have it built but I am not going to rush a $5k motor
I will bring my 2.5 liter stocker up to SZ and whip up some 3 liter...lol jk
