Hi everyone, I've own this car the last 1 1/2 years. It was 27k miles when I got it and was just fine in the drivetrain, the only problem with it was the A/C (it still is a problem). The last 6 months I step on the gas because of my schedule. Never missed the basic maintenance. I've changed the fuel pump (low pressure), the tensioner pulley (2 times because it was worn), the drivebelt at 32k miles, the alternator pulley (worn) and voltaje regulator (malfunction), refrigerant deposit (leak), oil and oil filter every 2.5k miles, air and fuel filters every 5k miles, last ATX Fluid change was at 35k miles.
Half a month ago I've noticed some lack of power, the engine hesitated at high RPMs in Park and Neutral and my brakes were low, I took it to the dealer and renewed the brake pads and the spark plugs. The hesitation problem is still there, the car starts and runs ok even at full throttle but not as good as the year before. Sometimes the engine makes whistling noises, specially after I step on gas. When I'm in a stop with the A/C on, the car vibrates a bit for 3 seconds, then it idles ok for 5-6 seconds and vibrates again.
I'm planning to change the ATX Fluid again (my car is almost 50k miles now), because I do a lot of engine-braking (I know I should not). But I need some other suggestions to solve the hesitation and whistling problems.
Thanks in advance!
P.S. Excuse me for my poor English
Thanks in advance!
