my98SVTturbo
im planning on buying the nautilus turbo kit around august. What needs to be upgraded for this kit? if anything. (clutch,lsd,flywheel,spark plug wires. etc....)
Clutch- yes
LSD- yes
Flywheel- why wouldn't you?
spark plugs- yes
Wires- I dont think you have to
relocate your battery
injectors- come with kit
Search man.
i did searxh but didnt come up with too much..the main reason i asked this was becuase i wanna get the kit on asap. im planning on upgrading the hardware but not just yet. I just wanted to make sure the engine could handle the turbo for a little while with out blowing up or what ever. thanks for the information everyone. I apriciate it
Everybody keeps saying flywheel but I don't think the flywheel is necessary to upgrade. All the aftermarket ones available are just lighter not necessarily stronger so upgrading would be nice to improve your throttle response but otherwise it's not a necessity. Just make sure you have it machined.
The main reason the flywheel usually gets recommended is because it's cake to install if you already have the tranny pulled for the clutch and LSD. Not one reason why you wouldn't want to do it.
....... other than the $300 pricetag. For someone on a budget, lightening the stock flywheel would be a good upgrade.
Mark
Not disagreeing at all, but why wouldn't you want to change it?
I was planning on going with a SPEC flywheel in the future when I beef up the tranny more, but now I'm not sure.
