bullitt3246
New CEG'er
My blinkers have been working fine since I've had it. Then the headlamps went out. Well, it had a HID kit installed and I figured that was the problem. Anyways, I took the entire HID headlight kit out and replaced it with factory bulbs. Turned out to be a fuse to the MAIN Headlamps.
Anyways, NOW the blinkers will not work unless the high beams are on.
The hazards still flash like normal. When you DO you use the blinkers with the brights on they blink REAL fast. They seem to blink WAY faster than the normal speed. My mustang blniks faster when a bulb or something is out.
WHAT could this be? All the blinker bulbs work when the brights are on....
