Pole120
Addicted CEG'er
After reading the brake FAQ i found...
"-Type A calipers are on all Contiques, Cougars, and late model SVT Contours. The pads for these calipers are thin and long compared to Type B. This caliper has two mounting brakets, one for 260mm rotors and one for 278mm rotors."
If i put in a 99 SVT in Tirerack only the rears show as available for Hawk performance pads.
Now if I input a 99 contour SE in Tirerack i can get the Hawk performance pads front the front and rear, and since the calipers are supposedly identical these will work correct?
