TourEnvy
I have a 2000 SVT w/ 60K, I was pulling a P1518 when I bought, and I couldnt see any movement in the secondaries when i worked the throttle accordingly (past 3500 RPM). So while i was at the junk yard, i said hell "lets pull a IMRC to swap." So, $20 bucks later I left with a box and cut cord. So last night I got home and swaped the box out using the cable that was in the car (not a to bad of job). Now I didnt disconnect the battery, just did the plug. whil I had the cable disconnected i had sure i worked the secondaries and not broken or frayed. After I got it back together I started the car and worked the throttle initially and there was movement in the connecting linkage, assuming it was working. However after it ran for a little bit more, the idle dropped, the linkage moved and I could not get it to move anymore by working the throttle.
This morning I went out and disconnected the positive side of the battery for about 15 min. put it back on and started it up no cel, but also no secondary movement. after another start it came on.
Did i reset the PCM correctly? Also what are the chances this IMRC is doing the same thing as my old one or is there anothor contributing factor creating th IMRC to work similar. Also If some could help me out to tell me where the front linkage should be when the secondaries are closed and open that would be helpful ei. "the cable pulls to keep the secondaries open, therefore moving the frontal linkage backwards". Also can some one confirm how to reset the PCM "fuse 6 and 11"? thank you. I may think of more questions. Thanks
