Ok--first off. We're talking about a 98.5 contour SVT, stock. Repairs done so far--new alternator, new plugs and wires, new fuel filter. This car has been a little sickly recently. Basically, it seems the car is losing power, jerking, big time, throughout the driving range. It often runs fine, but some days it wakes up on the wrong side of the garage, and just doesn't want to work right. We all have days like that, sure Anyway, the check engine kicks on and off, can't remember the codes, sorry, but the catalytic has been associated with these codes. Catalytics have been tested, and came back clean. Whens its really bad, the car won't even start-turns over but won't start. Today,for instance, running bad as soon as I backed it out. The RPM needle just dropped suddenly with the jerking. No noises, just the sudden loss of power. At a stop light, the rpm needle was trying to hit zero, trying to die on me and I had to pull over and do some investigating. We have observed that a certain connecter might be at fault. The lock was broken when we replaced the alternator. I am going to attach a couple of pics to look at. When I fiddled around with said connector today, the car started back up and didn't have any of the above symptoms again today. HMMMM...... However, another ongoing problem kicked in. When the clutch is engaged, the car revs up to 3-4000 rpms. Makes me sound like a jackass, and probably wastes gas to boot. Once again, doesn't do it all the time, just when the car is in a bad mood So, if there is anyone out there who has some good advice on this problem, we would be much obliged. My husband and Dad are going to poke around tomorrow and see what they can come up with. Hopefully, something productive. Thanks again for any useful input.
