shotwell
"I'm not trying to rub this in your face, nor tasso's. I don't think others are trying to either...it just comes off that way. No one likes to admit when they're wrong, especially on a public forum. That and it's a very expensive mistake."
The second Spec 1 clutch that failed in the first day, went in with a new (never used) Fidenza flywheel. Sorry to shoot a hole in your assumption right away but the clutch fell apart because it was defective.
"You have the answer right here. Yes, the machinist may have only taken off less than a mm, but how much was it worn down by the previous clutch? The flywheel face is a wear point while the step is not. That step HAS to be machined to specification EVERY time. Even as little as one mm of slack in that specification would cause early clutch failure...overheating causing metal fatigue, causing disentegration."
If your statement was correct and the machinest takes the same off both surfaces the result would still be different than when the flywheel was new due to the wear on the flywheel face. This small difference is not going to cause the low mileage failures experienced.
I wasn't talking about your clutch. Either of them. This response was for 8000RPM. I don't know what happened in your cases as I have not examined any evidence.
Go back and read my post again. Did I say to take the same amount off both surfaces? No. I said machine it to specification. I thought you had all of this experience...?
