69Boss302
Has mile high skills
ok, so yesterday my new scanner came in and i pulled the code instead of counting a light. I also cleared them all, and went for a drive to see what would happen. The Contour Enthusiast light came on for a few seconds and then went off. Unlike before where it would stay on.
These are the codes.
EDIT: Car info. 1995 Contour 2.5L MTX75
637 Trans Fluid Temp above max
522 Vehicle in gear or not in Park/Neutral
621 Trans/Shift Solenoid circuit malfunction
622 Trans/Shift Solenoid circuit malfunction
652 TCC Solenoid Circuit Malfunction
624 Elec Pressure Control circuit malfunction
667 Trans range sensor below min voltage
667 Trans Range sensor above max voltage
I have not had a chance to get under the car to see what that trans wiring looks like. But U have a sneaky suspicion that when the trans was replaced, that the wiring was damaged.
Any other thoughts please?
TIA
TIA
