There are many things that may cause this problem. And without know what your setup is (every amp, wire, speaker, etc.) It sounds like more than just a bad ground. It sounds like a current is being induced (bleeding) onto your wiring. Cheeper and non shielded wiring can cause this. Basically all electronic equipment puts out a small electric field. This field is picked up by other wires. The more you have the worse it gets. It gets pretty complicated. This is one of the times that money does buy quality. Never buy cheep wires. With that said. Check the wires from the battery. If either one is wrapped around another wire, this will cause bleeding. Once this happens, every amp in the line will do exactly what they do, amplify the noise. Also, all your amps should be in the same place so you can make sure they are all grounded to a common grounding block. You can also try grounging the amps to each other. You could also have a bad amp. Now, when I say this, I don't mean the entire unit. I don't want to get to technical, but each amp has many smaller amps inside it. If even one of these is bad, it will only get worse the farther down the chain you go. I hope some of this helps.
