nafunu32
I've found a couple of Stock SVTs in my area that I would love to pick up and then turbo. The problem is, they all have 100-135k miles on them. Is that too much to be running enough boost to hit high 13s with?
You may get away with just installing new rod bearings, and use Clevite 77's. But if you going to turbo a pree 2000 SVT you'll have to keep the boost low (~8psi) as the pre-2000's have a thinner oil ring land that people have shown to break once they start cranking up the boost.
If you are worried about rebuilding a 2.5 so that you can run boost reliably you're kind of taking a step backward. Honestly putting in a 3 liter will be close to the same price as a rebuild + a turbo kit. Sure you might make more power and sound cool cuz your car is turbocharged, but running the 3 liter will definitely be more reliable in the long run. Plus think about it, if you spend all that money and actually make 30-60 more hp then the 3 liter you're gonna have to compensate, because obviously your drivetrain won't be able to stand up to that much power for long. The stock clutch is only good for about 220hp and who knows how long your stock diff will last either.
The turbo set up will pretty much fit on the 3L when the 2.5 does go right?
