Cooling Fan not working after changing the fuse
Notz
Be Gentle I'm New Here
Hi,
my cooling fan is not working after I changed twice the fuse.
It works for a minute and than the fuse breaks, with no cooling fan no air condition,
what can help?
Notz
Sounds like a short somewhere if it keeps blowing..Check over connections and wires etc..someone with more help will Chime in..
Welcome :) . Check the fuse holder and connection at the bottom. In addition, wiring from battery to fuse box, fuse box to knob, knob to blower. Was the other speeds working before this happened? or was it only working on high speed? If only high speed prior to this, you have to change the blower resistor.
