BigBalledOX
Cross-posting here because the knowledge base is considerably larger then on NECO. For those of you who don't know, I have a 3L/SVT hybrid. I will be happy to provide any further information requested.
I've been getting a lovely tapping/clattering sound. Unable to pinpoint it, I took it to a shop and they determined it was coming from the upper engine.
Now, I made a couple of assumptions here and this may end up being very bad for me, but its too ****in late now. Knowing the HLA's are somewhat notorious for going bad and making a sound similar to what I described, I made the potentially foolish assumption it was just one of them starting to go bad.
I've heard of people driving for plenty of miles on them, and so I accelerated plans to have the new engine installed, thinking it made more sense to do that then to repair the HLA's since the engine was coming out of the car for overhaul before sale anyways.
Now, tonight, when I was driving home, I noticed the car had NO power, at ALL. Since the noise started, I've been very gentle with the car, but I was merging on to the interstate and there was just no punch at all.
When I was getting off the interstate, the car died on me. Now, this is not an entirely unusual occurance, so I simply put the clutch in and restarted it. The engine barely turned over, the car made this horrendous squealling sound, and then the car died again.
I tried a couple more times with the same result. Finally, I got the car to start and stay running, but it was still making this horrific sound. Fortunately I live at the foot of the interstate, so I was able to get home and park.
I opened up the hood to check the oil just in case, and the oil was fine, right where it should be. The squealling noise seemed to be coming from the front bank, near the accessory pullies. Now, back at Cougarfest I was thought to have a spun bearing, but upon opening the car up, we found the spark plug on the front bank, nearest to the accessory pullies to be finger tight.
I didn't have the heart to open the car up tonight and check things, it was getting dark and I'm super depressed right now because I'm having so many issues with this engine.
After talking thing over with another member, he speculated its possible the HLA has actually collapsed, and the car is misfiring due to one of the valves not fully opening. Now, this is sort of a stupid thing to assume, but I've heard of people driving thousands of miles with bad HLA's, so I'm wondering if there's any out there who have had it collapse?
The other possibility I am considering, the one I'm praying for, is the spark plug has worked its way loose again, and the tapping/clattering was from the spark plug vibrating.
To recap the sound, it makes it at startup, and then when the car is under load. When the car is not, if I'm coasting, the sound is almost gone . . . almost.
If anyone has any ideas, I'd really appreciate them, but right now I just wanna cry.
