Learn what i did, 393rd Bomb squadron electronic warfare AFSC 2A553C( bomber Defensive Avionics). I wasn't in charge of just one aircraft. I wasn't a crew cheif who was stuck on one aircraft. We had 10 but rotated a few for depot maintence. So for EPR's and everything the superiors claimed 8 aircraft. On a average day i was doing stuff on atleast 7 aircraft. So 8 x 2.2 Billion = 16billion ish.
Learn USAF operations, yo
squadron I used to be in:
http://www.whiteman.af.mil/organizations/393BS.shtml
about 2 weeks before I got out the maintance side seperated from the Flight Operations side to this squadron:
http://www.whiteman.af.mil/organizations/AMXS.shtml
I don't know you bro but, I pulled a little info from your CFETP about the duties and respoonsibilities of a journeyman in your career feild.
4.2.2. Electronic Warfare Systems Journeyman (2A553C). Performs and supervises maintenance on avionic EW, intercept, and analysis equipment. Isolates malfunctions by inspections, voltage checks, resistance measurements, waveform observations, and other tests using SE, built in test equipment, or computer aided diagnostics and manuals. Adjusts or
replaces defective units or components. Repairs avionic EW, intercept, and analysis equipment. Repairs intercept, panoramic, and radar warning receivers; jamming transmitters; dispensers; signal analysis equipment; recorders; direction finders; digital computer subsystems; and special
purpose SE. Tests repaired components for proper assembly using bench mockups and test equipment. Adjusts, aligns, and calibrates equipment. Overhauls modules, including replacement of components using hand tools, soldering equipment, and specialized electronic instruments. Modifies EW equipment, and installs components according to technical publications. Posts entries on maintenance and inspection records. Installs and removes
internally and externally mounted non-munitions avionic EW, intercept, and analysis equipment. Checks equipment for serviceability. Assembles, connects, and inter-wires equipment. Operates and maintains reprogramming and memory loading devices. Verifies configuration of installed EW equipment and software. Operates, and tunes, and adjusts equipment.
Straight from the CFETP (Career Field Education and Training Plan). Avionics Troops Kick @55 and take names. hua
