lovemycountour
Be Gentle I'm New Here
- Joined
- Feb 7, 2007
- Messages
- 3
99 SE - 187K miles
99 SE - 187K miles
1999 SE, 2.0 Zetec w/MTX.
I'm the original owner of this car.
Routine maintenance as follows:
Oil changes every 7K w/ synthetic oil (mostly Mobil 1)
Cooling systems flushed and refilled every 3 years.
Warped dash was replaced twice while under warranty, last time with revised part (after recall). Dash still rattles and squeaks, though.
80K - Alternator and serpentine belt replaced
90K - Spark plugs replaced
110K - Front brakes and rotors replaced. (Pads still had some wear left, but the rotors were worn out!)
150K - Replaced resistor module for blower motor control.
170K - Ignition lock stopped releasing the key. I replaced it the lock, but it didn't help. I figured out how to get it to release and I just live with it that way.
180K - Rear suspension started squeaking. Haven't done anything about it yet, but I'm planning to...
186K - I finally found out that this car has a timing belt! (I'd been told by the dealer that it didn't have one.) Replaced timing and serpentine belts, along with all idlers and tensioners, water pump (original was still fine, it turned out) plugs and ignition cables.
187K - Blew fusible link on ignition circuit. I still have no idea why, but I'm carrying a spare now - just in case.
It's on it's third set of tires and second battery.
Car does not leak or use any fluids and runs beautifully. I average 32-34 MPG in current use (20% city/80% highway), but have gotten as much as 37 MPG in all-freeway driving.
I have a couple of recent issues, such as hard starting (suspect IAC) and a possible worn top motor mount, but nothing too major. I plan to drive this thing as far as I can get it to go. I'm aiming for 300K...
99 SE - 187K miles
