CSVT1214
Addicted CEG'er
Sounds like the same thing that happened to me after installing the clips wrong. Double and triple check the clips.
A missing clip will be an entirely different feel. The brakes will still function ok, but may cause a shake, and the pad to wear uneven.
My 00 SVT had both clips installed wrong after replacing the pads and when I started up the car, it couldn't even hold itself in the driveway with the pedal to the floor. It kept changing from no pressure, to a small amount of pressure, but still not safe enough to take it on the road.
So I went in to Midas on Friday to have my lifetime pads replaced and the rotors turned. About an hour later, they come to me with a problem. After they put everything together they said the pedal didn't feel right. When you push the pedal in, it goes almost to the floor before you feel the brakes engage, but once you release the pedal and immediately put your foot back on, it has full pressure and everything is normal. But if you ever release your foot for more than a few seconds, pressing the pedal again will cause it to go to the floor.
They pinched off the driver's side front caliper and everything was fine. They decided the caliper had failed. Then they replaced the caliper but that didn't fix it. Then they decided the brake line had a leak or blister or something. They replaced that. Still didn't fix it. They didn't know what to do and decided the car was fixed and released it to me. They said maybe the pads need to sink in before it will work properly.
I've been driving it for two days now and i feel it is unsafe to drive. The pedal is unpredictable and too soft on first application. It basically requires me to pump the brakes before I can actually stop. I tried a few emergency stops and it almost feels like the brakes are coming on at different times, with the front left being last to come on.
I want to take it back to them so they can fix it, but they don't know how. Any insights as to what could be causing this?
From another thread. Not the best picture but you see where it goes.
