todras
Pretty fly for a white guy *cowbell*
From Terry...
upon stripping an MTX today we found it impossible to pull out the two shift fork rods that the forks slide on.They had to be removed 'en masse' with the gearsets...Once the fork and rod assy's were out of the trans the rods were KNOCKED OUT of the forks with a hammer and brass drift!...Think the forks wre a 'bit' stiff on the shafts???? ...So...why?...Well the residue in the trans was good 'ol ATF!!!...I'll say it one more time for the masses',ATF over a period of time,causes build up of black oxides within the trans and affects the soft metal bushes on 'stoc' shift forks and causes them to become very stiff on the shafts...DON'T USE THIS CRAP!...This is one of the several reasons Ford changed the spec from ATF to the'honey' type fluid.I don't care what Harry,Bill ,Fred,'my tech','my trans shop',The Senate,The Queen or the Pope says!!!! DON'T USE ATF IN AN MTX75....!!!!
This is a short vid of a fork rod and forks.The first fork I slide on is new with std bushes,the second is one from a trans that has spent its life in atf...I have a bit of a problem sliding it down the shaft!!!
Right click save as
....here is another redo of the test..This time I use a hammer on the same forks...The ATF fork is #1 in this.I can't labor the point enogh on this lube issue .The bunk that some owners and so called experts spout makes me sick.
Right click save as
Right click save as
Right click save as
