So back in Early December my temp gauge pinned itself past hot.  Car isn't overheating...
The belt drive on the driver side of the motor sqeaks. I has a belt with less then 4k on it. And last night I put on a new tensioner. It still sqeaks!
I'm guessing the waterpump is on the way out...Any other opinions?
Also how do you change the water sensor and what is the part? All I keep finding is thermostats and I know that's not what I'm looking for. Also I'm not sure how to remove the sensor/wire. I tried following the wire back, but it seems to just bundle into more wires. (???)
And it looks like my sensor has popped out, it has alot of play in it. If I push on the back of the rubber cap for the sensor, it pushes back out. :shrugs: Help!
