CSVT1214
Addicted CEG'er
95 Mystique Zetec ATX
All of sudden a few days ago it started misfiring very badly. So far I've tried a replacement coil pack and plug wires. No change at all. I pulled all 4 spark plugs and they all looked fine, and smelled fine with the exception of cylinder-3.
It has a slightly darker color and strong gas smell. You have to tap the gas to get the car started. Idle is very rough. The exhaust sounds are exactly like a misfire. Once the engine is warmed up, it will not idle at all. Stalls out right away. Loss of power.
Knowing that it's getting spark, and the injector is releasing fuel, are there any other possible problems that would cause the plug to smell of gas? At times, the exhaust smells very strong of gas but it comes and goes. My brother said in the last month or so before this problem, he gradually needed to tap the gas to get the car started more and more.
