djBACh
...hope im using the correct terminology here.
'95 contour GL - 2.0 4cyl - automatic
bought this car 6 years ago and it has always had this issue...
when i go to change the sparg plugs (which i do several times a year) the plug wire shafts and boots are covered in oil at the bottom. not just rubbed on, but dripping with oil. have always just changed everything and got it back on the road thinking 'oh well - ill get it looked at and fixed at some point'. but ya know - a busy guys tends to forget about things when they arent broke, and they think about thinks like the transmission that had to be replaced, or the timing and water pump that had to be replaced, or the struts that have to be replaced, or the numerous other little issues...
...anyone else have this problem or know what it may be? is it an extensive and expensive repair?
thanks!
b
thanks!
b
