98.5 SVT
1998 3.0L block
2.5L ported and polished SVT heads with 3L valves
Pauter forged rods
Ross 8.5:1 forged pistons
Street flight turbo kit - T3/TO4E turbo
HKS SSQV BOV
6 psi right now
42lb injectors (from what I was told, not sure how to check)
Ok, so here are the codes that I'm getting right now after 20 miles:
P0141 - O2 sensor heater circuit malfunction (bank 1 sensor 2)
P0161 - O2 sensor heater circuit malfunction (bank 2 sensor 2)
P1401 - Manufacturer control axillary emission controls
P1409 - Manufacturer control axillary emission controls
P0172 - System too rich (bank 1)
P0175 - System too rich (bank 2)
The car will die after a hard throttle if you let off the gas, or will stay running if you give it a little gas right after the hard pull.
ALSO, after about 5500RPM, the car makes a fluttering sound (HKS BOV opening?), and seems to stay at or loose power, but definitely does not pull any harder.
The auto meter Vac/Boost guage reads 6PSI at peak boost, and the turbo is on what I was told is the stock spring, it does not have a boost controller.
1998 3.0L block
Pauter forged rods
HKS SSQV BOV
6 psi right now
