Frank T
Took the CSVT to the local Ford dealer because I've been dealing with a intermittent cold idle problem....Back in 2005, had the cats replaced under federal warranty at same dealer, in 2007 same dealer installed rebuilt MAF....Last year around Thanksgiving, car started having the cold idle problem, meaning wouldn't hold idle while cold...Took to a local shop and they couldn't figure anything out except saying change out the K& N filter because of excessive oil....Still had idle problem....Fast forward to April 13 where I took the car to local Ford dealer....They found the following:
1.Faulty MAF Sensor
2.Misfire at #1 cylinder-cracked spark plug
3.Bank 1 CAT lost efficiencey
4.Baro reading 143 hz causing incorrect fuel control
5.All spark plugs have excessive gap
6.Fuel level sending unit reading erratically.....
Codes that came up P0301,P0420,P0460,P1100,P0300
So I approved the above repairs meaning another MAF(rebuilt)new CAT,new fuel pump and filter which came out to 2343.72 but they took off 10% so came to 2121.71 because they promised me the car on a certain date and they couldn't deliver on time...
Fast forward to Sunday April 26...When I start the car while its cold, it is searching idle .....will go up to 2k and then back down to almost dying... Also check engine light came on.....Took the car back on Monday, they gave me a rental and cleaned the throttle body and changed out the upper intake gasket and EGR gasket.....Another 353.00......So in the past three weeks I've spent almost 2500.00 on a 11 year old car with 138k miles on it....If it last another year, I'll be happy.......SORRY SO LONG OF A STORY!!!!!!
1.Faulty MAF Sensor
