Disclaimer:
This is a compilation of suggested ways to reduce the weight of your Contour/Mystique. Removing/replacing mnay of the items below can result in safety issues. Use this list at your own risk.
Suggestions are welcome. Please stay on-topic with suggestions only.
-> DemonSVT's weight distribution / reduction post
Informative sites:
Mumm's Brothers Cougar
Saturn weight reduction, well documented
Remove:
- airbags
- air conditioning system: ~30lbs for condensor, compressor, accumulator, and most hoses.
- bumpers
- ceiling lining
- center console
- cruise control
- floormats
- glove box
- hood liner
- jack
- mechanical traction control
- mirrors (sideview, rearview)
- passenger and rear seats
- power window system
- rear deck lid cover
- sail panels
- sideskirts
- sound deadening materials
- spare tire
- stereo system (4 speakers, amp, HU, antenna, etc.)
- sunroof system
- traction control, mechanical: ~3.25 lbs
- windshield wiper (mono-style or none)
- wiper fluid system
- unused seatbelt systems
- trunk lining and trim
Replace:
- battery -> relocate to trunk and/or lightweight (Dynabatt or motorcycle racing battery)
Lightweight battery write-up
- brakes -> Wilwood, TCE packages
- exhaust -> offroad y-pipe
- glass -> Lexan
- headers -> MSDS / Weapon-R
- hood -> carbon fiber
- pulleys -> lightweight
- seats -> lightweight
- suspension -> Ground Controls + Konis (15lbs lighter than stock)
- suspension -> D2 coilvers + Konis
- trunk -> carbon fiber
- wheels -> lightweight
- y-pipe -> BAT, SP
Modify/create:
- Max Extrude Hone Upper Intake Manifold (~5lbs red.)
- Grind/polish exterior of Upper Intake Manifold (~1lb red.)
- Steering column assembly (~15lb red.)
RogerB said:Grassroots Motorsports, May 03.
Based on power:weight,
30 lbs out of a 3000 lbs car is equal to a 1% increase in horsepower.
30 lbs out of a 2500 lbs car yields the same as a 1.2% increase in engine output.
And that's static weight. Rotational weight is more significant.
Informative sites:
Remove:
- airbags
- bumpers
- ceiling lining
- center console
- cruise control
- floormats
- glove box
- hood liner
- jack
- sail panels
- sideskirts
- spare tire
- sunroof system
Replace:
- glass -> Lexan
- y-pipe -> BAT, SP
Modify/create:
