CEG Forums
Go Back   CEG Forums > How-To's > M&M HOWTO
M&M HOWTO Modifications and Maintenance HOWTO documents
Reply
Thread Tools Display Modes
  #1
Old 02-16-2009, 09:07 PM
PurpleMystique PurpleMystique is offline
Gone.... Forever
Default How to: Blower Motor Resistor Replacement (Fan only works on high!)
Recently, the heat/air fan on my sister's '99 Zetec ATX started only working on high, no matter where the fan speed knob was set. Instead of paying $75/hr for a mechanic to troubleshoot and fix this, I fired up CEG and found that it is a common problem. My local Ford dealer had two of these in stock, I believe the price was around $16. I noticed a lot of "where is the blower resistor" threads, so I thought some pictures could help.
It's located in the front passenger footwell. It's an awkward place to get to, let alone take a picture of, so I tried to take several. In this picture, the tan piece you see is the center console, and the part we're looking for is the white plastic part with the four-wire plug facing the firewall:
Mine was held in by a single torx-head screw, it wasn't too difficult to get out. If you don't have a torx bit handy, an appropriately sized flathead should work.
Here it is with the resistor pulled out:
Here's what a bad resistor looks like:
Somewhere along the line, Ford redesigned this part. Here's the old one compared to the new one, you can see that the plug is rotated 90 degrees, but it's not a problem:
Here's the new one installed:
Once you manage to cram yourself into the footwell somehow, replacing this part takes all of five minutes.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
blower problem...(high only) devanmc General Troubleshooting 10 01-24-2008 05:29 PM
Blower install on high mileage car Avenger Forced Induction 19 12-05-2007 07:54 PM
Blower For Air And Heater Not Working snappydwp1 General Troubleshooting 13 08-20-2007 11:15 PM
Blower fan works when it wants dtsharp General Troubleshooting 7 05-30-2007 10:39 PM
Now for my next issue...blower works on one speed...HIGH mhhwilly67 General Troubleshooting 8 03-11-2007 01:45 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
