PD2GETU
Guest
ok , Im getting aggrivated ... the dealer said to remove the daytime running light relay under the hood in the relay box , so i did , and the lights were off .... i thaught i was in the clear , when i tested all the lights one of the high beams was out , and i put the relay back in , and the headlamps were both on high beam with the switch on .... any way to disable the daytime running lights without losing a high beam ? The running lights stay on regardless if the engine is running or not ... i do night work , stake outs , repossessions , so i need darkness when i turn the headlight switch off . anyone know ?
