My '98 Contour Duratec V6 shifts erradically at around 40 and 70 MPH under light throttle. I have a stored diagnostic code of P1519 which indicates the IMRC is stuck open (or closed). Would a faulty IMRC cause the transmission to shift erradically and what would I need to do to fix the problem? Two years ago I had to have the upper intake gasket and lower intake manifold gasket replaced because the car would die immediately after starting. I'm somewhat car savvy but no longer have the time or patience to work on my cars anymore. (Maybe my age has something to do with it since I'm not a "kid" anymore.)
