Shogun51
So I have a problem. The background story is I had a motor mount break and the motor twisted yanking the axle out of the trans. Well i put new mounts on the car and put a new axle in(the splines where sheered off on the old one). Now my problem is that the new axle I have will not clip into my torsen diff. I took all the fluid out of the trans and there was a little bit of metal in it but it looked like it was all from the axle. I can see the side gears on the diff and the dont appear to be damaged. But the new axle just wont clip into the diff. It the trans works and the diff seems to work but because the axle wont clip in it moves around just enough that all the tranny fluid leaks out. what could be casueing this? Do i need a new diff? Does torsen have a wranty like quaife? Please no flaming or stupid comments. Right now all i need imput and ideas of where i should go from here.
