Imrc
SVTJON87
Glen Ellyn, IL
how can i test to see if the imrc is opening up the secondarys? i just dont know when driving it. i may have gotten used to it opening. you know how you get a car its quik and before long it just dosnt feel quik anymore.
If you rev the engine from under the hood to the throttle body you should see under the mechanism moving to open the secondaries when it goes past 4000rpm
While you're looking under there, check to make sure the linkage is secure. I've read of many cases where one bank is no longer connected and functioning.
