Well, here's the old one:
Not visible in the photo are several spots where there is visible evidence of arcing. Maybe that has something to do with my wife's report of recent intermittent stalling.....
Here's the repaired harness, ready to re-install:
My local NAPA was out of red #10 primary wire, so I ended up with green.
A couple of points in above writeup that I can complement based on my 98:
1. There is no need to remove any of the relays or fuses from the box.
2. There is no need to remove both internal sections of the panel from the enclosure.
3. Remove only the bottom cover (it just snaps off/on)
4. The small section of the fuse panel that has the three large fuses just unclips and then pulls up to gain access to the screw connectors so the tee-connector can be removed from the fuses.
5. I also removed the battery tray to give myself some extra room. You may find this to be optional.
6. To open the crimps, I locked the tab in my 5" bench vice, then used my center-punch to drive into the crimp to open it. Re-crimping was done with vice-grips.
Took me about 3 hours excluding the trip to NAPA.
Steve
