Hey everyone.
So, I have had this blinker problem for a while, steady getting worse.
When putting on the turn signals, sometimes they work, sometimes they don't....they will blink for a few turns, then all of a sudden stop. If I tap on the blinker handle repeatedly they might start working again off and on. Also, the hazard switch is having this problem as well.
Is this the multifunction switch (turn signal switch) going bad? Also, is there not a relay to check, or and I just left replacing this switch for $100?
Thanks for any help!
