My #6 plug threads failed (plug popped out) in December '06. I repaired it with a thread repair kit (tap to larger size hole, and screw in a sleeve that accepts the plug) and it has run fine since, but the #6 wire has failed twice since that time (causing misfire code P0306). The only thing I know of that is not ideal about my fix is that I did not screw the replacement sleeve down far enough -- i.e. the "lip" of the plug boot sits about 1/4" above the plug access hole instead of flush on it like the other plugs.
Could this somehow cause the #6 wire to fail periodically? I keep an eye on that plug hole to make sure dirt doesn't get in, and splashed-up water getting in seems unlikely but possible. Maybe condensation is entering thru the gap and somehow causing the wire to fail. Another thought I had is that maybe the sleeve does not provide a good electrical connection to the block, causing the electricity to seek other paths to ground - such as thru the wire, causing damage (this would be a horrible design flaw of the thread fix kit). I am hesitant to mess with the thread fix, but maybe I can screw it down a bit further to close the gap (if this is the problem).
Has anyone experienced this before? I searched and could not find a similar situation of periodic plug wire failure.
Any ideas or opinions would be appreciated.
