TourEnvy
I remember seeing a How to for A pillar gauges in someones Sig. Anyone know who it is. I want to see if it has any additional Information for the job than I already have.
For oil pressure what about the port just below the TB on the block?
I ended placing mine temporarily in the head. I used -an fittings and braided line. I will only have to get one fitting to make it work down on the block. the setup is using a remote kit with braided line is super nice but super $$. I ilke it though.
What did you have to remove to get the spot behind the AC compressor? Since i went with -AN I had a piece to connect the line to the head, the line itself, and piece that connected to the sending unit. I curious if mine ended up being cheaper because I didnt use all those adapters. :laugh: I remember reading that you used hard line but I dont have that much experience with it.
TourEnvy said:My impressions were you cant use nylon tubing with an electrical sender??
oh BTW Brapple's post about pressure readings in the head was dead nuts.
Which post? I am curious what's been reported for those numbers.
