Redlineracer12
Addicted CEG'er
Before and after swap numbers. I was able to get them to pull up my old numbers for comparison so the graphs that have two distinct separate lines are current vs. two years ago. Super super smooth power curve
whp and wtq
whp and afr
Old and new dyno numbers on the same graph
I'm pumped!!!
Thanks to the greatest Contour tuner of all time, Warmonger, for making it possible
Edit: quick performance mods list.
2001 3.0L Taurus 24 Valve Shortblock brand new
2003 Taurus Cylinder Oval Port Heads – port matched to SVT Lower Intake Manifold (PnP)
4 angle valve job on intake and 3 angle valve job on exhaust
2007 Escape Oil Pan and pickup tube
SVT Cams, SVT Lower and Upper Intake Manifolds, SVT valvetrain
Borla SS Catback Exhaust
Trubendz SS Test pipe with Hi-flow Cat
MSDS Shorty Headers and y pipe
GMK Cold air intake extension w/ K&N
SCT XCalibrator 2 Flash Device with custom tune
Ford Racing 9MM blue plug wires
Autolite Finewire XP104 plugs
Power steering and alternator underdrive pulleys
SPEC stage 3+ Clutch
Findaza Lightweight Flywheel
Torsen T2 ATB Differential
whp and wtq
whp and afr
I'm pumped!!!
