How-To: Sail Panel removal
Ray
Addicted CEG'er
Humble
Vehicles: Contour/Mystique
Year: All years
Tools: Phillips screwdriver
Time: 5 minutes, max.
Difficulty, 1-10: 1
CEGer Nick DiNitale said:
Open the door and on the inside behind triangle, there is a
screw.
Remove this and the black plastic triangle it secures.
There will be another screw which secures the trim piece, remove this
screw.
Then, from the outside, push the triangle towards the front of
the car with the palm of your hand. It should come off easily. DO
NOT LIFT AWAY FROM THE CAR! This will break off the three retaining
tabs that hold the panel on. Installation is the reverse of removal.
