twocontours
95 contour V6 (OBD-I) running normal, intermittent check engine light and overdue for emissions.
Cleared old codes, ran for about an hour, KOEO test no current codes but stored codes set in memory, 332,543. Started checking egr, sucking on hose connected to EGR causes engine stumble at idle. Feeling hose that I took off EGR I feel pulsing vacuum.
Any suggestions on where to look next?
