Bradness
Who's got experience removing the crank damper bolt from a 2001 Taurus 3.0? I'm having trouble getting the damper bolt out on the motor I've got and was beginnning to wonder if it's LH threaded. I put the oxy aceylene torch to it and then the impact gun and it's a no-go.
I already cut off the front half of the shaft so I'm dealing strictly with the large (15/16"or 24mm) hex which is close to the damper.
