I just fixed this problem on my car.. lasted (PLAUGED) me about 8 months. Started out being once or maybe twice a week... then a day.. then every two or three minutes. Eventually I could even MOVE the car because it happened every second, twice or three times a second.
My symptoms:
- CEL light would "flicker", or sometimes STROBE very rapidly.
- PATS light would illuminate and do a 1 second "prove out" test, as if you just turned on the ignition.
- tach would drop/dive towards 0
- car power wasn't affected.. radio, lights, etc, remain
- fuel and spark were GONE during that time. no acceleration, no idling (when it got worse, that is).. nothing..
- voltage at the BATTERY wouldn't move.. would drop from 14.2 to 13.7-ish but that was only because the engine wasn't turning over any more and the alternator stopped producing power, for a second..
I checked everything. PCM power.. battery power.. IGNITON ITSELF (jumpered around the ignition to prove it wasn't the problem)
searched for loose grounds.. everything
The problem? a bad TPS wiring connection.
The TPS was fine.. the WIRING harness to the TPS was shorted, from the positive supply to the ground, which is a shared supply for a lot of the rest of the wiring harness, including the gauge cluster, the ignition, and the pats power.
Never in a million years would ANYONE that I told, or asked help from (on CEG, etc) have imagined that something related to the TPS would cause such EXTREME symptoms.
What should you do?
Check ALL of your grounds in the engine bay.
under the battery/fuse box
at the firewall on the passenger/center side, everywhere.
check the negative wires that go to the battery, and make sure they aren't loose in the crimped on ring that attaches to the battery.
then... the next time it is doing this, repetitively (if it gets worse and more frequent), unplug the TPS from the throttle body.. I bet it smoothes out and stops.
