CEG Forums
Go Back   CEG Forums > Engines, Drivetrain, and Power Upgrades > Duratec 3L
Duratec 3L Discussions on upgrading to a 3.0L Duratec engine
Reply
Thread Tools Display Modes
  #11
Old 11-03-2009, 12:58 PM
CollinsPC CollinsPC is offline
Default
Quote:
Originally Posted by CollinsPC View Post
You used the sprocket from the 2.5 and not the 3L? You just need to move the 3L sprocket to the correct position, not swap them out.
Pulse wheel is what I was trying to say.
__________________
Randy
Collins Powder Coating
Don't just color it, COAT IT!
www.collinspowdercoating.com
  #12
Old 11-03-2009, 01:10 PM
BrApple BrApple is offline
Section Moderator
Send a message via AIM to BrApple
Default
Quote:
Originally Posted by Cody4130 View Post
My car is a 2000 so maybe it uses the 3L chain and I can reuse the 3L guides and tensioners. If not my 2.5 is a clean strong engine that still runs great so the timing components should still be good.
maybe. it might have been a great chance of happening in a 01 and 02 cougars over a contour...but one never knows.
__________________
- 95 Mystique LS
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
Aircougar Performance
  #13
Old 11-03-2009, 01:43 PM
pwntbywombat pwntbywombat is offline
Send a message via AIM to pwntbywombat
Default
or you could just cover your ass and A. Use the 3L cams - use ALL the 3L timing components. or B. Use the 2.5L SVT cams - use ALL the 2.5 timing components like everyone else? Just a thought.
__________________
98 Black CSVT (Sold) #1244 03 3L.
88 Festiva LX 5 Speed - Daily Driver. 45+MPG!
  #14
Old 11-03-2009, 03:08 PM
Cody4130 Cody4130 is offline
Default
Quote:
def not going to use 3L cams so I'll be doing my 2.5 timing components.
Thanks all for the clarification. hopefully I can get what's left of the harmonic damper off tonight so I can take off the 3l heads and sell them. The outside broke away from the center hub
  #15
Old 11-03-2009, 03:11 PM
Default
mine did the same thing when i was taking it off the 2.5, the 3L came off just fine.
__________________
  #16
Old 11-03-2009, 10:30 PM
Default
I got what was left of the harmonic damper off wasn't as bad as I thought it was gonna be didn't even have to use a torch
  #17
Old 11-11-2009, 07:59 PM
Default
i didnt use a torch, i cut a slit in the base with a dremel wheel and it fell right off.
__________________
  #18
Old 11-12-2009, 11:23 AM
Default
recieved my 2.5 timing components yesterday (thanks 2000zxt) every part is totally different than the 3L stuff. The tensioners are about a 1/4" shorter but about twice the diameter of the 3L ones They are aslo much easier to push in. the chain guides are about twice as wide and are metal with plastic fronts instead of all plastic. The timing gears teeth are differend and it is also two pieces my 3L was a single gear.
Now all I need is a timing cover and rear valve cover so I won't have to take any parts off my Svt motor
  #19
Old 11-12-2009, 11:31 AM
SJon85 SJon85 is offline
Default
I might have missed this but if your not using the svt cams there isn't a need to swap the timing components over.
__________________
WTB: ST220, AEM wideband, unlocked xcal
  #20
Old 11-12-2009, 11:46 AM
Default
yeah, they are a little different. the tensioners are a pain. what year 3L did you get? my gears were 2 pieces just like the 2.5. Why the rear valve cover? no COP conversion?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Basic tuning overview mtxcontourSVT PCM Tuning 13 02-08-2009 03:50 AM
Another Timing Belt Question 96_ContourGuy Zetec Maintenance 6 07-13-2008 02:32 AM
Timing question LocoLobo General Discussions 1 06-18-2008 09:49 PM
96 2.0 Zetec Timing Question 96DeTour General Troubleshooting 6 08-16-2007 12:06 PM
very quick timing belt idler question volcomsk8a General Troubleshooting 1 01-25-2007 03:15 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
