byron366
Hey guys. Every 5-10 starts, the starter will grind making a metal on metal sound. It first started doing this in 2006, a year after we bought the car. My dads first impression was something to do with the shift interlock, so he would put in the ON position, press brake, and shift the shifter back and forth a couple of times. It worked. We did this every time. The car had a new transmission put in last year because of bucking, and the starter never grinded. So my dad thought the problem was solved. It wasn't. 2 months later, it started grinded again. This is when i brought it to my local garage, and the first thought is a bad starter. I was mad because they didn't check anything else, but they installed a new one anyways. It cost $297 for the starter (expensive considering it came from napa), and $100 for labor. That didn't solve a damn thing. Same problem again. Back to the shifting back and forth to solve it. My next impression was something to do with the PATS system, because sometimes we would jiggle the key and that would make it go too. The old keys were getting very worn, so maybe the car would think it was a fake. I bought a blank off ebay, (yes it is an original ford part), cut and programmed it, and still grinding every so often. Thats where i stand today. It grinds every 5-10 starts. Thanks for reading the long story, i just wanted to include what has been done to the car relating to the problem. If anyone has any suggestions, your input would be appreciated.
