Redlineracer12
made 196/219 untuned.
I think by looking at your dyno sheet it looks more like 196/185ish... The 219 probably came from the weird dyno blip so I wouldn't go by that.
I dont think its a blip, look under that and it says 215 torque...a blip for two runs...naI think by looking at your dyno sheet it looks more like 196/185ish... The 219 probably came from the weird dyno blip so I wouldn't go by that.
2--mildly ported oval port 3L heads, ported aluminum oval port LIM, ported or EH ST220 (I have one) and SVT cams
Either of those will have a custom SCT tune and also have a 65mm TB, 75mm ProM meter, NPG CAI, headers, With a fully custom 2inch True dual exhaust.
Just my plan, people may argue forever on this, but I'm pretty confident I'll do OK
-J
Dude, do you think much before you post?I'd say you could pull off decking the heads on a full 3l and getting an st220 uim and 65mm tb, simplest and least amount of crazy machine shop time.
It's okay to do...as long as you obviously get a tune.I thought milling them for more compression wasn't a good option for the Duratec.
-J
Why use a svt intake if youre going to go hybrid? Use a 98 3L style intake its biger and better obviously thats they its on the 3L. And look its similar to the st220 intake. Probably the same just a slightly different shape
not reallybiminilx said:Dude, do you think much before you post?
