my 98 se had a very similar problem, i replaced all my o2 sensors. my fire wall lower had the wrong plug and so did my radiator side upper. the only reason i knew i had the sensors in the right places was due to the wire length. i took the two wrong ones back to the store and just as you had to do i had to argue with them for 20 minutes before they checked a few other years and i had the right sensors in hand. i called ford and got this answer, check your production date in the door. if it was made after the 6th month of the year some parts may come from the following production year. he said most common parts would be fuel pumps, wireing, and some suspension componenets. is he right i dunno. i did however have to buy the sensors for a 99 to get it right. hope this helps.
98 se atx
cai
trubendz on the way
in the market for an svt
(unfortunately im always broke)
elyria ohio
