CSVT#49
Addicted CEG'er
Alright well I got around to installing the shifter tonight. Ran into a few problems. The bolts I bought need to be allen head bolts or torx head bolts because otherwise the reverse lockout can not be installed (not enough clearance). Now for the real problem, well sort of a problem I guess, the neutral return spring no longer fits. This is not a huge issue, but the shifter will no longer center the shifter. I'm curious to see what other people have done when installing the Steeda shifter...
However enought talk heres the pics (from my new camera, Nikon Coolpix 8700)
Remove shift knob and boot.
Disconnect the cable on the bottom of the shifter
Remove the C-clip on the side for the upper shift cable. Slide the lever assembly off the rod.
Remove the 4 torx bolts on top of the shifter assembly. For me they were T30 bolts.
Remove the top
Pull this shifter out
Peel back the rubber boot that holds the plastic bearing together.
Pull the plastic bearings apart and off of the shifter. I decided to clean my off to remove the old grease.
Use the new tube of grease and grease up the ball on the new shifter. Replace the plastic bearing back over the new shifter.
Put the rubber boot back over the plastic bearing to keep it together.
Stupid 10 picture rule... give me a few minutes
Remove the top
